IanFS
- Joined
- Apr 21, 2009
- 188
Hi Guys
Alpha one gen one 1988 sterndrive serial OC 345870.
I'm re assembling the the U Joint assembly to put back into the upper housing. I now require to tighten the lock nut at the end of the U joint assembly to attain the required pre load of between 6 - 10 in lbs.
I've followed the instructions in the Mercruiser manual which say that the nut should be tightened to attain the pre load mentioned above. Now I am in the process of doing it, the new Seal in the Seal carrier (that is the front seal behing the retaining ring) is creating drag.
Do you guys know if this would be written into the torque settings? This may sound like a very stupid question but the instructions are very specific in the note which says "Failure tofollow these instructions will cause premature failure" a little ambiguous I know but nevertheless important. I can't imagine they would be so dumb as to not take into account the drag on the seal??
What do you think?
What do you think?
