Drive Trim/Tilt clicks but no movement
Mr. Grumps
2006 350 mag mercruiser Bravo III
I have the one switch trim/trailer button when pressed you hear the clicking
noise but no movement. Did a search and see lots on alpha but none on bravo drives
Are the units the same? Can you point me in the right direction to troubleshoot
Thanks
Re: Drive Trim/Tilt clicks but no movement
Ayuh,... Bravos run the same pump as the Alphas do, 'n are pretty much the same wirin'....
Odds are ya got a corroded terminal or 2 that's causin' yer problem...
pismo10
The solenoids are shot, happens all the time.
