Re: drive unit service
The bottom hole will have a bottle of gear oil with a little hand pumped hooked up to it. You remove the top plug, and fill from the bottom. If you fill it from the top, you will end up with an air block. And it wont fill properly. You fill from the bottom till it starts running out of the top plug hole. Then you put the top plug in. Then u remove the pump connection from the bottom. Have the bottom plug at the ready and quickly replace it. ave a rag ready, and you shouldn't loose more then a teaspoon or so. You will figure it out. Then ya run the boat for a few minutes, on muffs in the driveway if ya want, and recheck the level at the top plug. If it doesnt run the top hole, the oil should be right up to the hole at least I have a bad feeling you may have bigger problems if there hasnt been any oil in for years....rust..ground up gears. good luck
