Re: driven gear bearings alpha one
That Bearing Also supports the top of the Input Shaft of the Lower Unit.......<br />It would be Impossible to remove with the Shaft in place........<br />Do it Right....<br />It'll only cost you a few minutes,+ 1 O-ring...............<br /><br />I Guess you Found your Noise........<br /><br />With all those metal shavings + such,<br />Now might be a good time for a Full Tear-down,+ Inspection,+ Reseal........
