Driveshaft Bearing help
hbryant123
I decided to start a new topic for this issue i have encountered. On my 105 hp two piece lower end i have finally got my driveshaft removed by tapping it and the seal out with a wood block and hammer. The trouble is now i noticed the bearing looked sorta brown and the shaft seemed to feel a little rough to spin and not smoothe and easy. How do i remove this bearing from the shaft and remove the race? I removed snap ring and the bearing wont budge!
Frank Acampora
Ok! Before you start you need to understand the design.
That lower unit uses two tapered roller bearings to support the drive shaft.
On ALL sets of meshing gears there must be a specific backlash or freedom of movement before the teeth engage. This is because there is a specific spot on the gear teeth where they must mesh. Too much or too little backlash and the gear teeth will wear even in the presence of sufficient oil.
Back to your lower unit: The top bearing is spaced by shims and sets the gear lash. Since this is a VERY old design the top bearing is held in place by a circlip on the shaft. The bottom bearing slides on the shaft. To ensure correct pre-loading of the bearings the pinion nut must be torqued to the correct specification AND must be a self locking nut. Since self locking nuts do deform with use the locking factor is compromised when you remove the nut. THUS: A new nut must be used when you re-assemble.
Now, It has been years since I disassembled an old lower like yours so bear with me. I know for certain that the bottom bearing slips off the shaft. The top bearing MAY be a slip fit or MAY be l light interference fit simply located by the circlip. At any rate if you want to remove the top bearing take a long piece of pipe that will fit over the drive shaft and tap the bearing down. Reach into the lower unit casting and using a long drift and hammer, alternately tapping each side of the race (Called the cup) work it out of the casting.
Just because a bearing is colored does not necessarily mean it is bad. Inspect the bearing and race for Bluing which would indicate overheating, pitting, and wear. If none of these conditions are present and the bearing rolls silky smooth then it is good to use.
If you decide you want to replace the bearing it is a standard one. The numbers will be stamped into both the internal and external race. Take the bearing and race to your local bearing supplier.
To re-install the bearing if it is a light interference fit, heat the inner cone over a 100 watt incandescent light bulb for about 15 minutes. If possible cool the shaft in a freezer. Then, with the circlip in place and using a thick glove, quickly slip home the bearing.
The light bulb heats and expands the inner bearing without supplying too much heat to damage it. Neat little trick.
hbryant123
Thanks for the advice, The bearing seems to roll pretty rough and not smoothe. i removed the c clip and it is not wanting to budge so i will try the pipe over the lower unit today. When i reassemble the lower unit what do i torque that nut to? I ordered a clymer manual from ebay so it should arrive soon!
Frank Acampora
I want to say 85 inch pounds BUT it has been so long I am not sure and I wouldn't trust my memory if I were you. Clymer may actually have that number.Remember to either stake the nut in three places or clamp it in a vise and deform the hole slightly to an oval shape--not so much that the nut will not start on the threads though.
