Tim Frank
- Joined
- Jul 29, 2008
- 5,346
Just reassembling this gem after resealing gearcase and with powerhead separated from exhaust housing.....for a second time....don't ask.
The OEM manual says to use a mix of "one part molybdenum sulfide" (I am guessing that is just grease) "to 40 parts OMC Sea-lube Anti-corrosion Lube."
I am all for following the manual explicitly....but up to a point.
I have a shelf full of lubricants....how critical is this....or is the Bondo rule ("any lube is better than no lube") OK here.
My inclination would just be to use one of the Anti-seize pastes that I have...e.g. Loctite 707....one of the usual silver, pasty compounds....or mix in a bit of moly grease as well....or just slap a lick of some decent grease on the splines and stop worrying so much?
I will wait for a few opinions/comments before proceeding.
