Driveshaft endplay, 1975 Johnson 75 HP
Model 75ELR76. I have the geacase apart to replace the seals and also replaced the driveshaft thrust bearing because it seemed a little rough. I then removed the original .010 inch shim and took the shaft assembly to the local shop to be shimmed. Much to my surprise, I was told it was OK as is, without any shims, so I reassembled the gearcase. I measure about .022 inch endplay on the driveshaft. Is this OK? I don't want to damage the gears. Thanks in advance for your help.
