Need a little help with removing the driveshaft retainer nut. I know about a 100ft/lbs. Hold it in place she stubborn in coming out. I need to remove it to inspect the clutch dog and forward gear, customer also bent the prop shaft hiting bottom.
Heat? Penatrating oil?T Trickof the trade?
If you believe these books everything comes apart with a simple twist.
For the record alpha1 gen2 2.0:1 upper
Dan
Dan
