blahthisnamenottaken
- Joined
- Jul 25, 2002
- 12
'63 75hp Evinrude<br /><br />My driveshaft and propshaft are a bit scored where the seals touch them (driveshaft a little more so than the propshaft). I assume it is from dirt or salt collecting on them over time. The depth of the grooves is around 1/64" or less, and I can feel the new seals catch on them when they slide past. <br /><br />Is this normal on older motors? <br /><br />Will it be a problem/should I go to the expense of having the grooves welded up and the shafts turned back down on a lathe?<br /><br />Thanks, <br />Rick
