Parrothead71
- Joined
- Aug 10, 2011
- 132
So I'm finally getting my lower unit back together. I ended up replacing the drive shaft with a good used one and the pinion gear as my original one was chipped. I measured from the flange on the shaft to the top of the pinion gear to determine what shims would be needed.
So now after assembly I can feel some vertical play in the shaft and hear the gears "banging" ,for lack of a better turn, when I have pulled up on the shaft.....it goes away after I push back down.
Is this normal or did I not get a good measurement? I am a machinist so I have access to some pretty good measuring equipment.
Oh the engine is a 1976 115hp Evinrude
