When I dropped the LU of my '87 6-HP Evinrude to change the impeller, the driveshaft came out of the pinion gear in the gear box and not the powerhead. I've clamped a vise grip on the shaft and hit it with a hammer but no luck.
Is heat the next option? Do I use a torch through the backside once I buy a thin-wall socket to remove the 2 bolts in that cover?
Here's the cover I'm talking about. Thanks!!!!!!!
