iwombat
- Joined
- Jul 12, 2006
- 3,767
Well, my replace the bow benches project has quickly turned into a replace the whole floor project. Yeah, I pretty much knew it would. The floor was still serviceable, but the old carpet was essentially just holding water against the wood in the floor. It was pretty soft and I couldn't see ripping up the carpet and leaving the floor like it was with a new covering. Besides, this way I can check out all the rivets and gluvit the interior.
I'm doing poly resin on 1/2-inch plywood which I'll then glass over and either texture & paint or cover with vinyl (still not sure).
On to the questions.
There's a few things that will be screwed into the floor and not glassed over, such as console pieces, seats, etc.
1) How do you keep water from running down the fasteners and rotting the wood out from the inside? Pre-drill and epoxy, coat fasteners with silicone, or something else entirely?
2) Between the panels is a pretty thin and weak strip of aluminum. I'm thinking of either replacing it with 3-inch aluminum channel (if the scrap yard has some) or, cedar 2x4s. Any drawbacks with using the cedar? How should it be treated?
Thanks, and happy new year.
