fishthebay
- Joined
- Aug 17, 2001
- 180
Hello Everyone:<br /><br />I am not a super mechanic, but did want to attempt to replace my waterpump on my 1987 85HP Force Outboard over the weekend. I do have the manual, but did have a few questions.<br /><br />After reading the manual on how to drop the lower unit it said the following.<br /><br />-Remove the Cotter Pin on the front of the lower unit that hold the shifter. (I did that)<br /><br />-Remove the exhaust snout 2 bolts and mark the position of the snout. (no picture in the maunual.)<br /><br />My trouble was here.<br /><br />I removed the outside bolt and then tried to locate the inside bolt, but it was really hard to see. After a few attempts I gave up, but still have some questions.<br /><br />-Does the inside bolt of the snout need to be removed?<br /><br />-After the snout bolts are removed is the only other thing holding the lower unit in place just 6 bolts?<br /><br />*My theory was to put a hydrolic jack under the unit and after all the bolts were removed to lower it very slowly so it wouldn't drop to the ground.<br /><br />-Is this the correct way? I don't know how heavy the unit is, but had my girlfriend on standby.<br /><br />-Also, what gear should the motor be in when dropping the unit? The manual didn't specify, but did say not to rotate the flywheel counterclock wise while reinstalling the unit.<br /><br />I will post some questions on how to replace the waterpump after I get the lower unit off.<br /><br />Any help would be appreciated.<br /><br />Thanks...
