RicardoMultibond
- Joined
- May 21, 2012
- 14
Out of the hole pulling a tube at take off it drops power like a rock. Did this 2 times last Wednesday, once on Friday and once on Saturday. Run fine all day on Sunday until time to go home. Had been floating around in the water every time for 30 to 40 minutes so I dont think it is a heat problem. The last time it done this is would not stay running. After the tow to the ramp it started and run fine. Pulled it to the cabin and started it again and it run fine. Any ideas? I changed the fuel fiter last year. I pulled the filter off and found no water or any trash coming out of it as I strained it through a paper towel. Could I have a vapor lock problem?
