Hi everybody ,Bill here again have a strange problem I have a 1984 140 johnson I have only been out a few times new to boating anyway had it out today starts right up idles great and moves along nicely.. My problem is that at wot we are doing about 5200 rpm`s I have a 13x17 prop new wires new plugs & wires had the carb`s open they are spoltless rebuilt fuel pump all new fuel lines and water seperator compression 118-120 all cyl`s , I would be running along for 5 min or so temp perfct and then all of a sudden it slows down on it own almost shut`s off and then picks up back to speed or rpm`s. Stick or throttle is not vibrating down checked it did it a few times ran the engine for about 3 or 4 hrs and ran great with that exception ?? I had the gas tank removed from the boat at the start of the season and flushed it out .. I think the rectifier/regulator (unfortunetly under the flywheel, the expensive one) is bad was curious if this would cause this type of problem?? any advice , thoughts would be appreciated ., Thanks Bill
