(from a de-railed post)<br /><br />I replaced my bulb. It is mounted in the usual place right in front of the engine.<br />But, each week when I go out, the fuel line is empty, and pumping the bulb sometimes fills the line, sometimes only after I have cranked the engine to create a vacuum.<br />I don't like this because the VRO pumps too much oil at first, dirting up my plugs.<br />I have a 65 gallon tank under the floor, so the fuel has to be sucked thru 5' of hose.<br />There is a inspection port hole cover, so I could mount the bulb right at the tank.<br />But, I was thinking of mounting a petcock (on-off valve) right at the tank, and elliminating the bulb all together.<br />As long as I remember to shut off the valve when taking the boat out of the water, it should work.<br />This way, there would never be any air in the line to bleed out.<br /><br />What do you guys think?
