ehenry
- Joined
- Jan 6, 2002
- 2,393
Had to purchase a new cook top for the kitchen. The old one we had is a gas 5 burner 36" glass top KitchenAid cook top that the igniter wiring burned up on. The new one we purchased is a gas 5 burner 36" stainless steel KitchenAid cook top. Now you would think that two 36" cook tops made by the same manufacturer would fit in the same counter top hole.....BUZZZ.....WRONG ! ! ! The new cook top requires a larger hole which brings me to my question......our counter tops are ceramic tile on top of plywood. Will a diamond blade in my angle grinder dry cut the ceramic? My plan is to use my 4.5 inch disk angle grinder with a diamond blade to cut the ceramic and then cut the plywood underneath with a sawzall. Will also have the wife using the shop vac hose to suck ceramic dust as I make the cuts.
Does anyone thats done something like this have any wisdom they'd care to impart on me so I wont be going in to this nekkid ?? I've never fooled with cutting ceramic tile just know the guy that laid it in the house used a wet saw.
