Dry gas???
Big-HE
I see the term dry gas from time to time...what is that? I had a problem with my motor running bogged down and 1/3 power. I changed my fuel line,cleaned the filter screen and replaced the fuel connectors because I notice bubbles at the tank fittings when I would squeeze the primer bulb. I just took it out and it ran alot better even close to full power in spurts but still hesitant for the most part but not bogging down...if that makes sense? Plan now to change the plugs and will adding an inline filter( or separator?) help at all???
Summer Fun
Banned
Re: Dry gas???
hi bighe :) dry gas get small amount of water out of gas so it will burn and won't frezee in winter :D
Summer Fun
Banned
Re: Dry gas???
hi :) any parts store or where you buy gas :) :)it's comes in 16oz bottles
RI_Bay_fly
Re: Dry gas???
I used some dry-gas last weekend and it solved my problem. It may say fuel-line anti-freeze on the plastic bottle. I believe the ingredient is methyl alcohol. I think I got water into the portable gas tank at the vent cap when I was rinsing the salt water off my boat. Someone said it can eat into your rubber fuel line or bulb so I would not over-do-it; just the recommended amount on the bottle and then try to use up that gas within a week, I imagine.
Big-HE
Re: Dry gas???
Is there another name for dry gas, because I can't find it anywhere?
Summer Fun
Banned
Re: Dry gas???
hi big he :) where did you look in 20min any parts store WiLL have it look harder :D look for gas line antifreeze :)
DaleT
Re: Dry gas???
I don't know if this has been mentioned to you before but have you tryed to "decarb" the engine. If you haven't the product that is used to do this is engine tuner, it is genarally available at marine engine stores.
Big-HE
Re: Dry gas???
Iwas trying to find some info on it online before I use it, is what I meant by I can't find it anywhere? Who makes it?
scotiany
Re: Dry gas???
even the drug stores here in upstate NY have it, not to mention walmart kmart sears et al
