spunkyman
- Joined
- Jul 17, 2011
- 153
I just got a 2007 Tahoe Q6 has a 4.3L Carb Mercruiser engine with dry joint manifolds and risers.
I was out on the lake and noticed that the temp was around 150-160 with oil pressure up around 70psi which I imagine is normal. The problem is that when I have the engine hatch open, looking at the engine, the riser on the left is HOT and the one on the right of the engine is COLD.... I removed the HOT riser and found no issues at all as far as water. The manifold still has water in it, so it's obviously flowing to there. The manifold itself looks to be in excellent condition with no blockages. Also, the spring loaded ball at the Tstat housing moves freely... I guess the water might not be getting to the riser? Wouldn't the temp gauge pick this up?
My question is .... is this normal to have one hot and one not? If the water seems to moving freely.. why the heck is one hot and one not ??!!??!!
