Bill Matuscak
- Joined
- Mar 14, 2004
- 22
I've got the transom wood and most of the floor wood installed in my project. I'm about ready to apply the fiberglass mat on both. I have a copy of Runabout Renovation and Fiberglass Boat Repair & Maintenance by West Systems. Between those books and reading this forum faithfully, I've progressed well.<br /> I'm using polyester resin and 1 1/2oz. mat. Here's my question. The author of Runabout Renovation always wets the wood with resin, then lays the mat and adds more resin to saturate the mat. The West System book talks of the Dry Method where you lay the mat on dry wood, then soak the mat with resin. They also mention the Wet Method (same as Runabout Renovation) but state it is NOT the prefered method.<br /> Which method have you folks used on your projects and what do you think works best? Also, the polyester resin is very thin. When you covered your transoms with mat or cloth how did you keep the resin and mat from sliding down and pooling in the boat bottom before is set? Should I staple the mat to the transom to prevent slippage?
