dry rot problem
MIKEY*2007
my deck on my 16 ft hartly plywood has got dry rot, to repair will cost $3,000 aussie dollars is there any product that will kill fungis instead of replaceing whole deck sorry for double post pushed wrong key
External Combustion
Re: dry rot problem
Any part that is discolored should be cut out and around 8 cm more. There are several products that kill dry rot. Any form of Copper Napthenate does it, one trade name is Cuprinol. Common salt will also work. Mix up a stiff solution and soak the wood thouroughly. You will have to keep salt on the wood to keep the dry rot from coming back as the spores are unbelievably tough. There are some new forms of wetable epoxy resin that not only encapsulates the spores and rot but gives adequate strength to continue using the wood. I have no personal knowledge of this stuff though. Some here will chime in on its effectiveness.
$3K is a bunch of replacement. What would it be if you did it yourself? Okeuma (sp) is readily available down there. I imagine the cost should be reasonable.
I know of one little 16 foot workboat that the deck is replaced every three years like clockwork because the owner is chemical sensitive. It costs less than $250 American in materials to do it right now. When I replaced the deck on my MFG Gypsie I actually used plywood from packing crates that were scheduled to be a landfill problem. It took me almost a day to do the job. All I needed was a portable saw a power screwdrive and a staple gun.
I am particularly lazy, so you can get by with manual tools.
Reuse your fasteners or order some good stainless steel or silicon bronze ones from a good chandler. If it is a salt water boat don't use brass screws as the zinc will leach out quickly and leave very weak fasteners.
gcboat
Re: dry rot problem
Okoume lumber is nothing more than another name for marine grade lumber - or plywood. It is manufactured to meet the British Standard 1088 (BS1088).
It has both sides sanded smooth, is laid up with waterproof glue. It is a lot more expensive than most anything you're likely to find in Home Cheapo or the other big box stores. Here's a link to a company that I just have in my favorites:http://www.jamestowndistributors.com/userportal/show_product.do?pid=15445&BASE
Another explanation of 1088 lumber : http://en.wikipedia.org/wiki/BS_1088
MIKEY*2007
Re: dry rot problem
thanks gcboat down under we call it marine ply,mike.
