Re: dt 140 gap and how to blead oil pump
Discussion Forum at MarineEngine.com: Suzuki Outboard: Bleeding oil system on 1987 DT 140
Posted by Andy Woodhouse on Wednesday, April 02, 2008 - 03:45 am:
1: Remove oil feed pipe from pump, fill oil tank, let all the air
bleed out of the pipe, attach pipe to pump.
2: There is a bleed screw on the oil pump, looks like a bolt but also
has a screw slot. Open it, blow down the oil tank filler cap until oil
runs out and then do it up again.
3: Run on half a tank of premix so you can be sure the pipes to the
inlet manifolds have bled themselves.
If number 3 worries you, you can pull the pipes off the manifold
fittings, plug the fittings (a piece of clamped hose will do) and run
in a tank until oil pukes out of the pipes, then re-fit.
You may have push on or banjo fittings at the manifold, if the latter
the pipes are clear and you can see the oil in the pipes.
