DT 150 Suzuki 1986
clevecan
What props will fit this motor? seems I have seen that other brands will fit. merc,yammy?
I'd like to know where I can find a used one.
eli_lilly
Re: DT 150 Suzuki 1986
If you're using a prop without an interchangeable hub, it has to be a Suzuki prop that will fit the older DT150s (they are not real common). If you're using a prop with an interchangeable hub, you'll need the hub kit for the older DT150. On my 1993 DT150, I'm using a Hustler with Turning Point Hub Kit 37. I got them from iboats.
Prop: http://www.iboats.com/14-1-4-X-17-Hustler-Aluminum/dm/view_id.195734
Hub kit: http://www.iboats.com/Turning-Point-Hub-Kit-37/dm/view_id.195764
Hope this helps,
-E
