Marion Moore
- Joined
- Feb 6, 2005
- 200
DT115 ?96 EFI ? Used, I have owned it for one year.
Saturday while running on muffs, I noticed that steam was rising from the tell tale water as it hit the ground. I touched the water with my hand and it was almost hot enough to burn you. No alarms. I cut the engine and felt the cylinder wall, it was almost too hot to touch.
I opened the water passages to find that there was a fair amount of corrosion and no anode. I have ordered an anode and cleaned the corrosion as best I could. I looked at the water pump and it is in great shape. None of the passages are blocked.
I have touched the tell tale water while boating and noticed that it seemed hot but I would expect it to. I have had the over temp alarm to go off in the past so I replaced the cylinder temp sensor and thermostat. Two trips later it alarmed again. Funny thing is I can shut the engine down and restart and it usually goes away.
I?m clueless here. What would cause the tell tale water to be HOT. Is it possible that I?m not getting enough flow with the muffs and the water is not making it to the top of the motor? The temperature alarm is bugging me too. Other than that and the worst fuel economy of any outboard ever produced it is a great motor. Any genius would be greatly appreciated.
