DT55 won't start
jreedham
Hi ... my 1985 DT55 has 2 problems. It won't start unless I spray gas into the spark plug hole, and it will stall at low, near idle speed. Carbs were rebuilt about 5 years ago, new plugs this year, new gas this year, was told it could be fuel pump. Any ideas??
99yam40
Re: DT55 won't start
need to pull and clean carbs properly and then adjust like manual says after reinstalling.
Would not hurt to check compression and fuel pump pressure/vacuum.
Inspect/replace water pump
jreedham
thanks for this information. I will try to find a manual to get the proper settings for the carbs. John
