DT85 Impeller and gear case seals.
dennyirl
have lower unit off and impeller off.down to what looks like a bearing? any idea how to get this out.bought an gearcase seal set also because there was water in with gearcase when i drained it.any ideas how i strip down further? :confused:
bowhuntrrl
Re: DT85 Impeller and gear case seals.
The two most common places for leaks are the prop shaft seal and the sealing washers for the drain/vent screws. The washers from Suzuki suck(in plain English) and are very soft. Even when tightening down carefully they can tear, at least in my experience with my DT-85. You really should buy a manual if you need to attempt further tear down.
dennyirl
have bought one but it doesnt tel you how to go down an further.it says nothing bout this bearing.its clymer manual i think?also how can i check if my thermostat is ok?
