My 1987 DT85 does not seem to have a spark on the bottom cylinder. The motor runs pretty good otherwise, and when you remove the bottom plug wire, it doesn't effect the performance one way or the other. I took the cover off the box where all the ignition wiring is connected and disconnected the bottom coil wire, and again, no difference. There was a spark arching over where the two wires connect, so it leads me to believe the bottom CDI coil is bad. This seems likely because there is a spark all the way to this point. In addition, the fuel and oil combination from the bottom cylinder, unburnt of course, leaks down the outside of the drive shaft housing, below the lower motor cover. Does anyone know if this is a common/likely problem? Also, does anyone have any idea where I can buy a new one, besides Brown's Point? Thanks.
