wittylou7582
- Joined
- May 3, 2010
- 10
I own a 1985 (i think) dt85 suzuki in which i put on my 18' ranger bass boat. I was having a problem with it going into gear. I took the lower unit off and messed with the shift rod, put the lower unit back on, and now it is going into gear fine. but the problem is, when it shifts into gear, it stalls out (within 2-4 seconds it stalls out). it seems to idle fine but i have to inject gas into the carbs to get it to fire. it will just turn over and will not start if I do not put gas directly into the carbs. so I am having a problem getting it to fire and I am having a problem getting it to go without stalling. i am only 18, i don't know much about boat motors. any help is appreciated. thank you
