Re: Dual Battery Charging
there is a way to achieve this.. you can install an isolator and connect your alternator wire to it and then subsequently to the two batteries, it will keep them seperated while charging both, you do lose about 1/2 an amp but should not be noticeable. but you would want to verify if your alternator uses a sensor and what amps it puts out to see if this option will work for you
