Re: Dual battery switching affect electronics?
Let's clarify. 1) If you are installing a switch that IS NOT a make-before-break style, do not install it. 2) Why would you start the engine on BOTH and then switch to BAT 1 to charge only it? The typical scenario is to start on BAT 1 (assuming it's your start battery). Switch to BOTH under way. Then switch to BAT 2 while fishing or at anchor listening to tunes. BAT 2 will be powering accessories at that point. When you get ready to go again, switch to BAT 1 to start, then to BOTH under way. Or just start on BOTH and leave it there when under way. Electronics will not be damaged when switching provided the switch is make-before-break. The only big NO-NO is never to switch to OFF with the engine running. That will cost you a regulator.
