ShoestringID
- Joined
- Jan 27, 2011
- 19
I am really struggling with this question and hope to get some good advice here...
I have a 15' fishing boat with a 25 HP electric start outboard, an accessories wiring harness/switch panel (bilge, livewell, lights), an electric trolling motor, an onboard dual battery charger, and 2 size 27 deep cycle batteries. I am wondering what the best way to wire all of this is to 1) always give me enough power to start the outboard and 2) make the best use of power for trolling with the electric motor and 3) give me an emergency safety margin at all times. One note: The generator output of the outboard is insufficient to use an automatic battery switch (or so the documentation states)
I am thinking the following would be a good option for me:
Wire the charger directly to each battery. In the garage the charger will be able to sense the needed charge in each battery separately and charge appropriately.
Install a manual dual-battery switch with a 1, 2, both batteries option and wire the batteries, outboard, and accessories harness to the switch
In normal running the switch will be set to battery 1. This will allow the outboard to provide a run-time charge to battery 1
Wire the trolling motor directly to battery 2 (not the switch)
This would allow me to troll from battery 2 without endangering the starting capacity of battery 1
In a battery1 power emergency I have the option of battery 2, or both to get the outboard started. In an "total outboard failure" emergency I have at least one charged battery to limp back to the dock with the electric motor.
If I'm being an electrical idiot please shoot holes in my plan
Much obliged to anyone that can help!
