stan_deezy
- Joined
- Oct 18, 2003
- 1,539
Hi guys!<br />It was my misfortune to buy a cheap Volvo Penta outboard and think I could restore it to its former glory......now I have come across a problem I have never seen and am stumped so I am throwing myself upon the mercy of the community in the hope that someone will have some answers.<br /><br />The engine was sold to me because "it wasn't pumping water". I stripped it down and discovered that the pipework wasn't connected up at all; so assumed this was the reason for non-pumping...wrong!! Here's a list of questions; if anyone can answer one or all I'll be very grateful (and very impressed!)<br /><br />1. This engine has two impellors in the water pump assembly (an arrangement I have never seen before). They are seperated by a metal plate and two gaskets. Why two impellors?<br /><br />2. Why does exhaust gas flow from the telltale (the hole under the clyinder block). I assume its exhaust gas; if I block the hole with my finger the underwater exhaust blows out air at a rapid rate of knots.<br /><br />3. With two impellors in a pump should they both be running in the same direction?<br /><br />4. Is there a rule of thumb as to which way the impellors should be running (no workshop manual available for this engine).<br /><br />5. Can I simply take the old impellors along to my local chandelry and get similar items or am I risking the wrath of the great lord Neptune?<br /><br />6. Can anyone tell me why there are two impellors and what logic is involved in this arrangement?<br /><br />7. Because the engine is a first time starter and runs sweet as a nut I am seriously considering and alternative cooling system if no-one can answer the above questions; it would go like this; electric pump mounted inside the hood with a pick-up pipe spliced into the old pump feed; has anyone else ever tried this and does anyone have any views on the pro's and cons of this system.<br /><br />Told you I had loads of questions!!<br /><br />I have got torn and tattered fingers from this engine but I feel she's too sweet an old lady to be put to rest so any help with this project would be much appreciated,<br /><br />best regards<br /><br />Bro
