Dual line connector. Rebuild?
merkdawg0084
Working on an FD-11 and found a dual line pressure tank locally. The connector that goes from tank to motor
seems to be stuck internally. I know you can rebuild these. Does anyone have a link on a “ how to rebuild” thx.
Crosbyman
use stainless steel turkey cooking (stuffing) needles and bend accordingly ...Dollar store stuff
oldboat1
Before more serious work, depress the springs with a probe and work some penetrating oil or ATF in. Work it a little.
merkdawg0084
I took it apart already, had a bunch of deteriorating rubber and old varnish gas in there. Thx though
MallRat
I rebuilt a dual pressure tank a few years back. Make sure the pressure release valve works. Also make sure the over pressure (?) valve works.
Here are a few links to convert that engine to use single line tank.
https://tinyurl.com/y7p7aqku
and
https://tinyurl.com/ybyafgeq
The last link has a lot of info on the older outboards if you use the link at the bottom of the page to go BACK ........
