Dumb Fuel Question
jimchere
'82 Evinrude 55HP 2cyl. Before starting the first time I pump up the fuel bulb about 4-6 times until firm. Is the bulb supposed to remain firm while operating? After running for a bit it is not firm at all. Motor runs fine. Just want to make sure I don't have an air leak, bad check valve, fitting, or carb float problem.
Joe Reeves
Re: Dumb Fuel Question
Jim.... The bulb is not designed to stay hard while the engine is running.
willxuout
This is normal. After priming the bulb and running the motor the bulb will not remain firm. If there was a fuel restriction between the bulb and the tank the bulb would collapse. If the bulb remains expanded but soft after running then it's working fine.
