Dumb question but need answer quick
sikz3
Which way does the thermostat go? Spring up or down? Since there was not one in there I cannot just put it the way it was.
1980 Omc 140 hp.
Thanks
sikz3
Re: Dumb question but need answer quick
That's what I was afraid of. Mine won't just drop in the hole. Are they pretty tight to get in sometimes?
SuperNova
Depends on corrosion of course. How exactly is it binding up?
sikz3
Took a dremel tool to grind excess corrosion so it would fit and did a compression test. Going from bow to stern, meaning 1 is toward the the bow 4 being toward the stern. 1= 125 psi 2=125 psi 3=130 psi 4=130 psi. What do you guys think? Is that good?
