Dumb Question re: Engine Trim
Sea Mitch
I have trim tabs and an engine "trim" built into the throttle for lifting and lowering the outboard engine ('93 yamaha 250). I have a gauge showing me the "height" of the engine. Where should the engine be for optimum power. Should I vary the height when getting on plane as to when I'm on plane? I can't seem to figure out when to lower or raise the engine or just use the trim tabs. Any help is greatly appreciated!
JB
Re: Dumb Question re: Engine Trim
Howdy, First Boat.<br /><br />I think the proper use of the trim is to start with the engine tucked in to lift the stern and as it comes up on plane trim the engine out to get best speed at the rpm you choose to cruise.<br /><br />Good luck. :)
blifsey
Yes, start with motor tucked under or all the way down. After boat is on plane, put throttle at RPMs your aiming to run at (of course to some boaters there's idle and WOT with nothing in between). Start trimming motor up in little bumps on the trim switch. There are three things I know of to find the "sweet spot". 1) When you reach too much trim up, boat will start to porpoise (bow will go up and down in in a rythym), trim back down just a bump or two to stop porpoising. 2) If boat doesn't porpoise when overtrimmed, the prop will begin to cavitate. You'll know this by the noise the prop is making and the sudden increase in RPMs. Trim back down until it stops. 3) When trim is down, boat will tend to pull right or left (I forget which one). As you trim up, you will pass a point where boat will begin to pull the other direction. Trim back down until boat runs straight. Your boat may experience one or all of these. On my old boat, I could feel #1 and #3. On new boat, I get #2. As you trim up, watch your speed. It can make several MPH difference. Also, if you slow down for a tight turn, you may have to trim down as the angle of the boat can cause prop to rise too high and cavitate (or slip).<br /><br />Not having trim tabs, I have no idea how to factor them into the equation.<br /><br />BL...
martinwinte
Check out this page for your trim info (also LOTS of tips and advice on other matters relating to boating). <br /><br />Boat tips
Sea Mitch
Great Replies! I'm going out this afternoon to try it out... Thanks Guys!
sho305
It is typical to use trim tabs to level boat while criusing, or to hold bow down in rough water so you can trim up some. They fake the boat into being longer this way, but can be dangerous if run down too far and you get in the air. They will catch, and turn the boat at speed. Also can help getting on plane, or planing slowly.<br /><br />If this boat can run high speeds for its size, get educated about how to drive it before getting gutsy with it. Things can get complex above 60mph in a 18' or smaller boat; maybe 70 with a 19' or 20'.
