Durabak Floor Coating??
HookMaster
Got on the web site for "Durabak" but wonder how well it will clean up after a day of fishing etc. Seems there is a good chance that the "textured" surface would be hard to scrub to get clean. Looks like it would tend to hold dirt etc. I don't want to apply it and not be happy with how it cleans up. Anyone out there that has used it for decking?
Also, applying gel coat to get a non slip / textured surface? Any methods that work?
PuddleJumper
Re: Durabak Floor Coating??
If it's anything like the Rhino lining in my truck, dirt will not be a problem. Mine cleans up with a spray hose and looks as good as the day it was applied.
Can't comment on gel coat issue.
MarkV_Deep6
If you use this stuff make sure you buy the UV resistant type. I used white with the textured rubber and wish I had used the plain or added my own sand for texture, is a bit on the over kill for non skid. Clean up is also affected by the non skid but is not imposible. A good dousing of chlorox and any stain is gone. So far it is holding up very well to my abuse.
HookMaster
I think I will opt to use something other than Durabak etc. I got a sample and think it's too rough. I might try to thicken up a whit gel coat and roll it on with a textured roller. Will try a sample piece first. Any other suggestions from the members?
studlymandingo
Not too sure on the textured roller application for gel coat. I think it would be self-leveling until the gel started to kick, then you would have a VERY short window to do the rolling. But, it never hurts to experiment, let us know how your sample works out!
DangerDan
I have the Durabak coating on my boat and it cleans up really easily. A little laundry detergent, water and a scrub brush and your in buisness.
