last week i found the one thermostat in my m8ts motor not working , replaced it & the port side was still getting hot then took the cylinder head off & found the deflector tubes closed up with salt & were hard up against the cylinder head gasket i couldn't see any water coming from there so i took them out & threw them in the bin , assembled & started again letting idle for nearly 2hrs , the motor was running sweet as & no over heat
