Can a Peak voltage Tester made by Ignition Mate do the same testing as a DVA meter? I have a Peak volt tester that I have not used, because I don't know how to operate it. The directions don't say much and I don't understand them anyways! But want to learn it real bad. Also would the measurements taken be the same for both of them? I never used a DVA meter also, but have some electrical experience. I would really appreciate any and all help on how to set up and use this peak volt tester.
Thank you for your time, Kevin
