jmactacular
- Joined
- Jun 29, 2012
- 5
I have a 1977 Johnson 25 HP (25R77H) pull start, that was ridden hard and put away wet.
Carb is rebuilt, everything moves, but no spark.
Next step is to test the resistance and voltage of the ignition components I had spark on the lower cylinder but not the top. So I removed both coils on the rear of the motor and cleaned up the block to create a good ground. i replaced the top coil and now I'm not getting any spark on any cylander. I have a feeling it might be the magneto sensor that tells the power pack when to fire, but I will test the voltage and resistance of the magneto coil, the magneto sensor, the power pack and the ignition coils.
2 questions:
Can someone tell me what the V and OHM readings should be for the ignition components for my motor? I have no battery connected so when OMC talks about the voltage across certain components I assume these are readings when the motor is being pulled over?
I bought a mastercraft 52-0052-2 multimeter and just need to know if the voltage readings that I will be taking from the meter can be compared to the ones specified by ignition manufacturers at the link below. I.E. are the voltages read on the meter DMA voltage.
OMC ignition troubleshooting
https://www.google.ca/url?sa=t&rct=...C6gRWNO4vnRi7ew&bvm=bv.49641647,d.dmg&cad=rja
Master craft multimeter
Autoranging Digital Multimeter | Canadian Tire
Thanks
2 questions:
Thanks
