DVA Voltage?
BBB2boater
Can anyone explain to me what is meant by 'DVA voltage' when discussing the power pack checks?
Thanks,
Tim
R.Johnson
Re: DVA Voltage?
The pack converts AC current from the charge coil to DC current. To measure this you need what is called a peak reading volt meter. A standard volt meter will not register. I'm not sure what DVA stands for, possible direct voltage adapter. They make one of these to work with a standard meter.
clanton
Re: DVA Voltage?
The peak reading meter reads the peaks of the AC sine wave.
