longstand
- Joined
- May 2, 2009
- 293
My Factory Setting is:
Point Gap: 0.018
Dwell: 37 to 41
V6 3.8L
Also i have to manually Open the distributer to change Point GAP. i dont have that little window which i could adjust for the dwell
I set the Point Gap on my First engine and when reading the Dwell setting while is running, it SHOW Constant 38 to 38.5.. I set the Timing to 10~BTDC.. Everything Runs fine and smooth..
The second engine i set the Point Gap to 0.018 and start the engine. i let the engine Warm up to normal operating temperature and i just the timing..
i check the dwell using my dwell meter and it jump around to 05.1 to sometimes it stay at 38.5. but most of the time it set to 05.1..
to fix the problem i try to readjust my Point Gap again and clean the rottor and the cap. .. still giving me problem.. the engine runs. but Dwell reading is all mess up.
also i have not fully adjusted the carburator yet because i cant seem to get dwell setting to stay in one Rating..
ANy idea
Point Gap: 0.018
Dwell: 37 to 41
V6 3.8L
ANy idea
