DynaHair
contractorguy
I found this at the autoparts store... I had no Cabosil, and they were out of Ooops! Peanut Butter. I needed to do some filleting.
It's kinda like bondo, but has more resin and lots of stranded glass.
Any body ever used it? I just did...layed in and tooled pretty nice. It kicks pretty quick, and can be shaped in 1/2 hour....Not bad.
oops!
Re: DynaHair
i havent used it
i would need to see whats in it
.....but i would imagine you have just found peanut butter in a can !
now we just gotta paint some squrrils on it :D
i386
Re: DynaHair
It's poly resin, glass, silica gel, and talc. Here's the msds. Sounds like Peanut Butter to me. I would prefer they call it catalyst and not hardener but w/e.
flounderman
Re: DynaHair
This stuff is similar to "KITTY HAIR", "DURAGLAS" & "BONDOGLAS". I hope you are quick and can get it right the 1st time. It is tough to sand. You may end up grinding. Have a 1" brush with some acetone handy and smooth your work before it starts to "kick".
erikgreen
Re: DynaHair
That stuff works fine for fillets. As has been said, try to get it shaped before it hardens though, because afterward will be a problem. Personally I have to do the same with my wood flour putty anyway....
drewmitch44
Re: DynaHair
Where do you get this? It seems like a good idea. Ooops youshould make your PB and market it! LOL You can call it ooops super duper
Re: DynaHair
Ayuh,......
That's just the typical Polyester based Tiger Hair,.......
As long as you're doing a Polyester based rebuild,.. It'll be Fine.....
It's Not for use with any Epoxy products though.....
It's available at Any autobody supply house.........
