E&S Model 200 EXTERNAL CATALYST MIX Gelcoat Dump/Spray Gun
redgin
Has anyone used the G200 Gelcoat Spray Gun I have been using a G100 but its a pain in the butt to clean the gun every time. So has anyone used the G200 and what do think and any areas I should look out for. Thanks for the help Bob
ondarvr
One of the most important parts of getting a good, long lasting gel coat spray job is using the correct catalyst ratio, on these guns the ratio is a guess at best, you really have no clue as to how much catalyst is being dispensed compared to the gel coat.
Can it work, yes, but it can be very inconsistent, to the point of complete failure.
Older, full sized gel coat spray equipment used a similar system, but it had several different adjustments that could be made to meter the catalyst flow, including a sight gauge that sort indicated what the flow might be. On these old units you needed to calibrate the gun before using it each time, some companies did it several times a day, others not at all. There are none of these old type pressure tank systems on the market anymore, they all went to a slave arm mechanism for a much more accurate and repeatable catalyst ratio.
Many years ago Binks came out with the same type of catalyst spray tip for their small siphon and pressure pots, it didn't catch on because of the same issue, no real control of catalyst ratio.
Don't mean to hijack your thread but I just ordered the G100, what makes it a pain to clean?
ondarvr
Nothing, they're about the easiest to maintain spray gun you can find, it takes more acetone to clean a paint brush. You need to do the same amount of cleaning on the 200.
ondarvr
The advantage of having a catalyzer is you don't need to worry about the gel coat getting hard in the container, so you can take your time.
