E tec 50 or JohnsonSuzi 50
backdraft
Decisions , decisions. Going to repower Gregor deep V aluminum boat rated to 60 horse. Which way to go? Johnson 50 four stroke or 50 Evinrude 50 or 60 Etec.<br /> nevjb
LubeDude
Re: E tec 50 or JohnsonSuzi 50
Just remember, The only place you are going to buy oil for your Etech is either At the dealer, or from Amsoil. There is a rumor going around that , No, Im not going to go there yet!
JB
Howdy NevJB.<br /><br />The Suzi/Johnny EFI 50s have been proven on the water to be great engines with happy owners.<br /><br />The E-Tecs look great on paper, but have yet to build a track record.<br /><br />If you like to be the first guy on the lake to try one, go for the E-Tec.<br /><br />If you want confidence in a proven engine, get the Suzi/Johnny.<br /><br />Good luck. :)
walleyehed
I think either choice would be OK, and as for the oil for the E-TEC, you have 2 great choices, both "very equal". :D
backdraft
Mechanics all, to do the valve adjustment on the Suzi/John, does it require the removal of the cams [dual overhead cams] or is there a tool to compress the bucket to get the shim out without removing the chain or cam? <br />What amount of running time is usual before having to do this? Anyone have actual hands on experience with this 50 four stroke? Quiet, reliable, satisfied? nevjb
seahorse5
The E-TEC has much less maintenance costs than a 4-stroke of any make. The Johnson (Suzuki) needs oil changes, plus the high cost of a filter each time, and periodic valve adjustments. The new tool cuts down on the labor to set the valve, by eliminating thr removal of the camshafts. A dealer has to stock a variety of shims in differnt thicknesses to be able to service the motor.<br />The E-TEC also has an automatic winterizing feature that the owner can do, also saving money over a 4-stroke.
jegervais
The 2003 Factory Service Manual lists valve inspection/adjustment at the 10 hour inspection and then every 200 hours or biannually. Oil & filter service is at 10 hours and then every 100 hours/once a year if using non-synthetic oil or every 200 hours/once a year if using Evinrude/Johnson Ultra 4-Stroke (synthetic) oil.<br /><br />The warranty flat rate pays up to 2 hours for a valve check/adjustment. As Seahorse stated, there is a special tool kit that allows the shim and bucket to be depressed without removing the camshaft.<br /><br />Idle speed for the 4-stroke (in gear) is 850 +/-50 rpm and is not adjustable.<br /><br />E-TEC idle speed is 800 +/-50 rpm and is adjustable down to 550 rpm or up to 900 rpm.<br /><br />If you troll, you may find benefit with the adjustable idle speed.<br /><br />Both engines have the an advertised weight around 240 lbs. Both engines run very smooth.<br /><br />If "clean & green" concerns you, the E-TEC figures are HC+Nox = 17.6 gr/kwhr and CO = 66.5 gr/kwhr. The 4-stroke figures are HC+Nox = 15.8 gr/kwhr and CO = 235.27 gr/kwhr. HC is Hydrocarbon emissions, Nox is Oxides of Nitrogen and CO is Carbon Monoxide (the killer).<br /><br />Alternator on the E-TEC is 25 amps, 4-Stroke is 18 amps.<br /><br />Hope this helps.<br /><br />-John
Forktail
Ensign
By seahorse - The E-TEC has much less maintenance costs than a 4-stroke of any make.
Very presumptuous, considering that the impacts of zero maintenance for 3 years have yet to be seen, especially in a salt water environment. I would guess that you're going to pay for it later.<br /><br />
By seahorse - The Johnson (Suzuki) needs oil changes
This is a good thing, not a detriment.<br /><br />4-stroke oil does more than lubricate. It cleans and cools. As a result, any quality 4-stroke outboard with a pressurized oil system will filter the contaminates. Changing the oil and filter every 200 hours is assurance to engine longevity.<br /><br />The benefits of being able to filter and change oil that is lubricating, cooling, and cleaning will always outweigh those of an unfiltered, pass-through oil system with oil designed to burn. <br /><br />
By seahorse - plus the high cost of a filter each time
Filters are less than $10 at your local parts store....about what one spark plug for the E-TEC will cost you. 4-stroke oil can be found for under $5-10 a gallon. Plan on $40 for a gallon for the $special$ E-TEC oil. If you use something other than the special E-TEC oil, plan on using twice as much of it.<br /><br />
By seahorse - periodic valve adjustments.
You mean periodic inspection. Adjustment is rarely needed, and only done if necessary. Most of my 4-stroke outboards require an inspection every 2 years. I can't remember ever needing to adjust any of them.<br /><br />
By seahorse - The E-TEC also has an automatic winterizing feature...saving money over a 4-stroke.
It doesn't cost much to disconnect the fuel line, run the engine, and squirt oil into each cylinder. And that's exactly what my 4-strokes require. Besides, nevjb lives in Nevada. Not much winter there.<br /><br />If you're concerned with costs, check out the initial price of a 50 HP Suzuki/Johnson compared to a 50 HP E-Tec.
clanton
My memery is not great, but the 4 stroke johnsons up thru 60 hp has a rocker arm with screw and locknut for valve adjustments, just like a very old 6 cylinder chev. One of the filters listed for under 5.00 before freight added. Some of them need adjustment at first service, the one I did last week had two loose intake valves, and the guy at the factory that glues the valve cover gasket in is sloppy with the glue. Valve adjustments never required removing the cam for any of the John/Suz 4 stroke. The valve cam setup for the larger engines is just like a Kawasaki Z1 900 CC from 1969, except 4 valves. If you have worked on any of the later model 4 stroke motorcycles from Japan, you should be able to handle the Johnson/Suz.<br /><br />Looks like 2004 40/50 has bucket cam follows and shims to adjust valves.
BillP
I'm not as gung ho on 4 strokes as others so I'd go with the 2 stoke and take a chance. <br /><br />Hey Clanton, how much do shims cost for outboards? I bought a Kaw 900cc in 76 and did the valve adjusting. It was an easy task. Shims back then were around $6 each. The real pain was having to run down to the dealer to get the right size after the motor was torn down. After a few adjustments I had a half dozen spares and swapped them around. <br /><br />Forktail, I noticed the ads for etec now say 3 years or 300 hrs for maintenance. 300 hrs makes it more believable.
JB
Gotta put in $.02 here.<br /><br />According to JD Powers, EFI 4 strokes are more reliable than all 2 strokes.<br /><br />The litany that Seahorse and BillP (first time I EVER heard someone who claimed not to like his 4 stroke) list about them is exaggerated and even appears biased.<br /><br />Routine and preventive maintenence on my 4 strokes (I have 2) is no more trouble than that required on the 25 or 30 2 strokes I have owned, and reliability is clearly better. Checking valve clearance (never needed adjustment) and changing oil once a year, dipstick, etc. is no more trouble than mixing or adding oil, cleaning carbs, etc.<br /><br />My Suzi DF70 EFI 4 stroke is a better engine than my carbed 9.9 4 stroke. . . always starts on the first spin, never koffs, spits, stutters or stalls. I have never owned any 2 stroke that I could say that about. The 9.9 often requires more than one jerk on the rope, but once it starts it is the same.<br /><br />Let's not get into bashing engine types or fellow members. Let's answer the man's question.
mattttt25
my father-in-law just repowered his 14' inflatable with a 50 e-tec. not the type to do a lot of research, just has the money to blow. he's only run it a few times (boat is in the bahamas at his condo), but he said it is absolutely amazing. very quiet, extremely powerful, no smoke, etc. no long track record, but sounds like good technology changing the marine industry.
seahorse5
We are talking about maintenance costs per the manufacturer's recommendation since the motors would be in warranty. Using factory items, a Johnson 4 stroke filter is about $13 plus about $3.95 for a quart of Bombardier 4-stroke oil or $5.95 for semi synthetic (200hr.) factory oil. Plus a nationwide average of $65 per hour labor, most dealers charge 1 hour for an oil change. You have to remove the motor pan to access the filter. So an oil change would be at least 65+13+16 or $94 per year. Winterizing by a dealer would be around 1 hour plus fogging oil, grease, and l/u lube, around $15 plus $65 or $80. Valve adjust for the 10 hr would be around $65 if none needed new shims. At the second year, the valve adjust would be probably the 2 hour flat rate, 65X2 or $130. The engine also needs annual service, tune up, and that may be around $125 with parts and labor. So for 3 years, a 4-stroke may cost in maintenance , 4 oil changes, including the 10 hr. ($376), 1 valve check plus 1 valve adjust ($195), 2 winterizings ($160), and at least 2 annual services ($250). Total for 3 years is about $981 in parts and labor, plus that means around 3 or 4 trips to the dealer, waiting for service, then 3 or 4 more trips to the dealer to pick the boat up.<br /><br />According to the factory an E-TEC would not need dealer service, spark plugs, or l/u oil (fresh water) for 300 hours or 3 years, and winterizing can be done automatically by the customer. Using factory XD-50 (FICHT Ram oil) bulk oil from a dealer for about $14/ gallon in which usage would be about 2 gallons a year ICOMIA averages (50 hours annually) times 3 years would equal $84. Even if you bought it retail in gallon jugs at $22, it would only total $132 for 3 years. Fuel consumption would be very close for either engine, so that is not factored in.<br /><br />No matter how you look at it, the E-TEC is a lot less expensive to maintain.<br /><br />Bottom Line:<br /><br />$981 maintenance cost for 3 years on the 4-stroke, or $327 per year.<br /><br />$84 to $132 maintenance for 3 years on the E-TEC, or $28-44 per year.
backdraft
I 'm finding out more each day on this subject. I'm going to the Sacramento boat show on the 10th to talk to the dealers and hopefully see an E tec in person. I was unaware the E tec had lower CO than the Johnson. The maintenance fugures are very interesting. Since I will do most of the maintenance , it doesn"t figure in quite so much for me. I would rather buy an original designed motor made in the US, however the Johnson seems to seems to be rather high tech in it's design. P.S. MY local dealer says the tach with all the sensors is extra but it seems Suzuki provides it in the motor package. Hoping to find out Wednesday. nevjb
seahorse5
Even the older FICHTS had fewer total emissions that the 4-strokes. That is the reason that Lake Tahoe uses them on their patrol boats, replacing the previous 4-strokes.<br /><br />Both the Evinrude and the Johnson are good high tech motors, and each accomplishes it's design parameters in different ways. Don't forget that if you are repowering from a Johnson or Evinrude, you can use the same control box and cables, and wiring harness and guages. Depending on what year you had, you may need a harness adapter kit if it is earlier than '96. You could still use your tach, and would only have to buy the 4-lite System Check gauge (2") for about $70. Or you can spend around $160 and get a new tach with the warning lites built in.<br /><br />Get a ride in an E-TEC if you can. Remember, you can glean more useful information from the tech personel than the sales people at a show.
BillP
Hey JB,<br />I've posted here many times about my preference on 2 strokes. Like you, I've also had 25 or so 2s in the last 40+ yrs...and a 50 4 stroke for 8 yrs. <br /><br />About JD Powers surveys...Do you also believe their survey that says Grady White is better than Boston Whaler?<br /><br />To nevjb I say...These are not your fathers 2 strokes. Buy a 2 stroke. Ignore the biased and highly exaggerated bashing of 2 stroke problems. After that, ignore the biased and highly exaggerated praises of 4 strokes. :D <br /><br />It doesn't mean I'm right, it just means thats the way I see it!
lakensea
To my esteemed colleague Mr Seahorse:<br /><br /> I must "tweak" your figures some. First, it appears Suzuki parts prices are less than Johnson. I get $8.84 for the oil filter and $3.06 for quart of marine grade oil. No synthetic. Also, at 50 hours per season, winterizing and oil changes would be done at the same time, as would the second valve adjustment/check. We find spring service involves little more than hooking up the battery, running engine and changing spark plugs if fouled from fogging oil - $12 if customer does it, add 1/2hr labor if we do it. Using the $65/hr labor rate and the dealer doing the spring service, I come up with about $600 for 3 years. Still more than your E-Tec, but less than you original figures. I have heard nothing but good things about the E-Tec and suspect I will be hearing more at our upcoming boat shows, so feel free to enlighten me if you see any flaws in my figuring.
Forktail
Ensign
That was laughable seahorse. Exaggeration is an understatement. I've never spent that much to maintain even my big F225's! <br /><br />
It's not necessary to take your outboard to a dealer, or use factory items to maintain your warranty. That is unless you want to see just how much you can spend!<br /><br />OEM equivalant filters and oil can be used. Maintenance can be done by the owner, or another experienced and less expensive shop. This will not void your warranty. <br /><br />My 4-stroke owner's manuals show many maintenance items which can be done by the owner. These include oil changes and winterizing, etc. Complete procedures are even in the owner's manual.<br /><br />
OEM or better quality replacement is under $6.00 at my local NAPA.<br /><br />
More like $3.65/quart for an OEM equivalant synthetic exceeding API specifications (200 hr).<br /><br />
Having your dealer change your oil is a luxury. Most owners do it themselves (in about 15 minutes). IMO, if you can't change the oil yourself seahorse, you shouldn't own a mechanical piece of equipment like an outboard.<br /><br />
No, an oil change would be about $14.00. That's $6.00 for a filter and 2 quarts of synthetic oil at $3.65 (the Suzuki/Johnson 50 holds about 2 quarts).<br /><br />At the end of the 300 maintenance-free E-TEC hours, the 4-stroke would need two oil changes (one at 10 hours, and one at 200 hours) equaling $28.00. The next change wouldn't be until 400 hours.<br /><br />
Winterizing or storing my 4-strokes simply require disconnecting the fuel supply, running the engine dry of fuel, and adding a teaspoon of oil to each cylinder. That's it. 15 minutes. Cost...zero.<br /><br />Fogging a 4-stroke (at least my Yamaha's) is not required. Although greasing and changing the L/U oil is a good idea before winter storage, it is not required either. Having your dealer winterize your outboard is another luxury.<br /><br />
You mean valve inspection. You're assuming the valves must be adjusted, which generally isn't the case. I have 4-strokes with thousands of hours on them, which have never needed valve adjustment. Valve inspection is again another thing the owner can do himself in no time. At least a less expensive shop (other than the dealer) could do it.<br /><br />
The engine needs what? <br /><br />Remember, the Johnson/Suzuki 50 is EFI. Not much "tune-up" there! Plus, according to your theory, you've already charged for adjusting the valves, changing engine oil, changing lower unit oil, grease, etc. <br /><br />
You've gone from using hours to using years. Again, in the 300 maintenance-free hours of the E-TEC, the 4-stroke will need 2 oil changes. One at 10 hours and one at 200 hours - it won't need another until 400 hours.<br /><br />Cost: $28.00. Not $376.00. <br /><br />
I'll assume the owner can check his valves, and that they won't need adjustment (since mine never do). If he can't do that, I'll at least say he can do it less expensively.<br /><br />Cost $0. Not $195.<br /><br />
I'll assume an owner can run his outboard dry of fuel and put a little oil in each cylinder. Again, having your dealer winterize your outboard would be a luxury.<br /><br />Cost: $0. Not $160.<br /><br />
Annual service for what?<br /><br />
Total for 300 hours is $28.00. Not $981. This is in line with the maintenance records of my F50's. Just oil and filters and a little owner maintenance.<br /><br />
Only if you want your dealer to change your oil and winterize your outboard. Luxuries have their inconvenience. Maybe you should take your E-TEC to the dealer every time you need to add oil?<br /><br />
The problem is, that could be said for any outboard. Any manufacturer could stretch it to that. I suppose I could go 300 hours on the same L/U oil too. Spark plugs? They could go 300 hours. Sure. And since my 4-strokes never see a dealer's shop in 300 hours, I suppose I could say they don't need service either.<br /><br />
Likewise, a customer can winterize his 4-stroke.<br /><br />
The E-TEC is designed for using $special$ XD-100 oil. I saw it for about $40 a gallon at my dealer. If you want to use XD-50 oil, you will need to take your E-TEC back to the dealer and have it re-programmed for that oil. Then plan on using twice as much of it. <br /><br />
More convenient maybe. And you have no idea about the expenses that will be associated with maintaining the E-TEC. <br /><br />Answer me this seahorse....<br /><br />1. Does the "no maintenance" thing apply to E-TEC's used on the salt water? If not, why not?<br /><br />2. Does the "no maintenance" thing apply only to "recreational" use? If so, why?<br /><br />3. How much does a E-TEC spark plug cost at the dealership?<br /><br />4. What's special about the E-TEC L/U that allows it to go 3 years without changing oil?<br /><br />5. Will "no maintenance" for 3 years cost more in the long run....say year 4, 6, or 8?<br /><br />6. What maintenance is required after 3 years?<br /><br />7. Did you factor in the large initial cost difference of the two outboards?<br /><br />8. Did you factor in the longevity difference of the two outboards?
moderator1
As usual, whenever this topic is debated it turns into an argument. Topic CLOSED.
