E115TLCO Gearcase Overhaul
Jachin
As my lower end is now totally disassembled it is time for the reassembly; hence new topic and next question. I'm waiting for my "factory" service manual, and meanwhile still working with the Seloc which states emphatically that all seals should be coated with gasket seal compound - however, in the detail of bearing carrier assembly (and driveshaft assembly) it states to coat the outside of the seal with Hi-Vis, and the mating surfaces with Triple Guard.
What goes on the outer edge of the seal - Hi-Vis or Gasket Sealing Compound?
remember, the Seloc manual is worth less than charmin butt-wipe.
use the factory service manual. you can probably find it on-line at boatinfo.no
Faztbullet
Gasket sealing compound on metal otter rim and tri guard on rubber lips
Jachin
As I said, the manual IS on it's way; just making due with Seloc for now; thanks for the clarification on the sealing compound.
