E140trlcte
trophyman
I'm looking at an Aquasport 170, yr?, w/ an Evinrude engine. It has been repainted but I think I see 140 outline on the cover. The tag had the following info: Mod # E140TRLCTE, Serial # J0286611. Does anyone have any info on the engine. YR?, longevity, etc.
Thanks
tashasdaddy
Re: E140trlcte
140 hp 1983. good motor.
BUYING A USED MOTOR
overall condition, condition of the place you are buying it from, usually tells you how they care for things. compression 100 + psi, and within 10% of each other, good strong blue spark, no water in the lower unit oil. look for discolored paint, (sign of over heat at
one time, also scarred up bolts, as why. have them start it. if they fail to put it in a barrell or tank, or on muffs, or in the water, to start it they don't know what they are doing. best yet is to take it for a 30 min to 1 hour test run. also if remote controlled motor, the controls should come with it.
Daviet
Re: E140trlcte
I can't speak from experience on that motor,never had one.But I can tell you it is a 1983 - 140 horse.
