E15RCEC Transom Clamp Screw
shooter5636
After a less than desirable week in terms of boat repairs, I've come across another mishap. I removed the motor from my duck boat to replace a cracked transom. At some point I managed to bend one of the transom clamp screws. I looked up a part number and came up with 377311. I googled the part number but only came up with the full assembly, not the screw. Where can I find one of these? Also, are all Johnson/Evinrude clamp screws the same thread count? I did some googling and found clamp screws but none of the part numbers matched my year.
oldboat1
aluminum. should be able to straighten it, would think. Use a punch or small Phillips screwdriver and bump out the pins in the handle, then remove the screw. Probably just straighten it by clamping it in a vise.
shooter5636
I'll have to give that a try. I'd still like to order one just to have even if I do get this one straightened out.
