Bruce Alan
- Joined
- Aug 21, 2004
- 23
My extremely rusty old trim and tilt motor finally gave up. I tried to remove the assy from the engine today. No luck. The manual release screw head is stripped. I was able to get the electric motor to turn (intermittently) enough to get the engine raised and then lowered onto the tilt support. after a lot of scraping and some struggle I was able to remove the snap rings from the upper and lower pins. My trouble starts here. The pins will not budge. The manual says to use a punc and hammer. I have used a punch and hammer from both sides and copious amounts of penetrating oil. there was a lot of corosion evident around the snap rings. I believe the next step is heat. <br />I'm concerned though because the hydraulics work fine and I don't want to melt a seal and end up with a total rebuild on the unit. I just want to replace the electric motor. Any guidance would be greatly appreciated.
