E60ELCRE Lower unit seals
jcjspringers
I did a complete lower unit reseal and new water pump. What I can't find is PN 305762. BRP online (ref # 17) has it listed as a gear case seal. Its a 1/4" tall foam ring. Didn't see it at all when I removed the lu. A forum search shows that it may go on the water pump, but old pump had exact same parts as the the new one. Is this an extra part to cover multiple years of lu's? Again '84 60 horse long shaft.
Thanks
jcjspringers
Re: E60ELCRE Lower unit seals
Ezeke,
I would assume it goes into the exaust housing before the grommet (ref #70)? If that's the case, I would assume that it plays very little into sealing against water intrusion into lu. I will inspect tonight.
Thanks
Joel
jcjspringers
Yep, Posted before the pic was up. Thanks again Ezeke.
This project will be much easier when my service manual gets here.
